 VC186 ROTJ Boba Fett the a**l review
volkerc Posted - 03/12/2021 : 12:52:37 PM
Constructive Criticism Review
Those who know me know that Boba Fett is my main collecting focus.
Many others on the "The dented helmet" and the RPF and myself have
researched Fetts different costumes over a long time. A lot of
reference material is out there as well as confirmed used parts of
these costumes.
When the new Rotj Boba Fett was announced I was hoping to get a
figure similar to 6 inch quality in 3.75 inch size. However some
details of the costume are so small that once you try to bring
them to 3.75 inch size they get lost. So keep this in mind. Also
you need to keep in mind that lighting has a huge effect on colors
so if you think you see a dark green in bad lighting it is
actually much lighter shade. The propmakers painted Boba Fetts
green armor not simply in one solid color green, they sprayed
different layers and shades of green and sprinkled black and
other shades above the final layers of green, which gives the
basic color more depth, are more realistic used and faded look
of the color. That can not be done for these small figures be it
3.75 or 6 inch, so Hasbro would need to find a compromise for
the colors.
The initial 3D rendered images of the new Boba Fett figures
sported an ESB helmet on the Rotj figure. That was corrected,
somewhat. Unfortunately we were never shown a finalized proto.
The first images of the final product came from fans who found
these figures in stores in the U.S.
Now that I have some lose ones in hand I can compare them to the
movie version of Boba Fett. It's good, but not the "definitive"
version that some think, but it could be with some tweaks. The
main problems are with the jetpack and the boots, colors, blaster.
For some, these do not matter, because it's Boba Fett, for others
that keep striving for the best costume it is a problem.
Helmet, the helmet seems to be modeled after the scan Hasbro took
from the original helmet, which gives us the correct size.
Judging from a copy I own that was pulled from an original helmet
I don't see any differences, which is good! The colors are now
Rotj except the cheeks appear too black, needed a tint of green.
Killstripes is a miss, I'm counting 14 but Rotj has 18 killstripes
ESB helmet comes with 14 killstripes. The color of the
killstripes however is a match for Rotj. Helmet is a 9 out of 10.
Chestarmor. Is a miss, it's lacking the lights on the left chest
plate, symbol on the right chest plate is perfect, green armor is
too dark as is the cod piece. 7,5 out of 10.
Jetpack, this is a pre production jetpack in colors! This jetpack
was worn when Fett had yellow and red gauntlets, this jetpack was
not used in Rotj. The blades on the rocket is a carry over mistake
the rocket has 3 blades not 4. Because it is a pre-pro jetpack
the colors are way too bright, lacking the silver on the small
exhausts. A plus is the vent on the bottom, 5 out of 10. 10 out of
10 if this would be for a pre-pro Fett.
The pouches on the belt are great even appear to show some
stitching. 10 out of 10.
On the back the 2 strings that hold the horse girth belt in
place are black leather not structured like the girth belt. The
figure is lacking black paint but the strings are present.
9.5 out of 10.
The jumpsuit has the correct washed out color, 10 out of 10.
Gauntlets have the correct shade red, everything is molded that
needs to be there, including 2 buttons on the left gauntlet, but
one dart is missing on the right gauntlet, I see 3 instead of 4.
9.5 out of 10.
The cape has the correct color, correct length, 10 out of 10.
The blaster is a 7 out of 10. The rusty look is perfect, size
is accurate, not too big not too small. Problems are the stock
greeblies are from the ESB blaster! Rotj used different greeblies!
A Webley which this blaster was based on comes with one bronze
pistol grip on the right side, the left side is flat, and the
grip is not present as it's just a metal piece that attaches to
the wooden stock.
Shoulder armor is a 10 out of 10. Attached nicely to the flak
vest like the real deal which gives the figure more movement
possibilities. Shoulder and knee armor could use a little darker
shade.
Boots, I don't know these are somewhat killing it for me.
They look like slippers, I'm missing the distinct shape of the
boots. The figure looks like it wears socks, the center stripe
is there, but the look,... :/
Overall the figure has great play value, good looks but lacks in
correct detail. It is no comparison to the VOTC Rotj Boba Fett,
it could have been a 10 if the above mentioned flaws would not
be present, in fact this figure could be the ultimate Rotj Fett
if these issues could be fixed. Hasbro would never have to fiddle
with another Rotj Fett as this sculpt would hold up for decades.
Diejenigen die mich kennen wissen das Boba Fett mein Hauptfokus
in meiner Sammlung ist.Viele Fans von Boba Fett haben auf Seiten
wie The Dented Helmet und the RPF lange Zeit die verschiedenen
Kostüme ausgiebig studiert und recherchiert so das es sehr viel
Referenzmaterial und bestaetigte, gefundene originale Teile gibt.
Als Hasbro den neuen Rotj Boba Fett bekannt gab hoffte ich das
sie mit ihren neuen Techniken einiges an Detail von den 6 inch
Figuren in die 3.75 inch Groesse uebertragen koennen. Was
schwierig ist da das Kostueme viele Feinheiten besitzt die wenn
man sie runterskaliert verloren gehen. Das Boba Fett Kostuem ist
das detailreichste, teuerste und schwerste Kostuem zu kopieren.
Je nach Lichteinfall veraendern sich die Farben. Wer glaubt das
das Kostuem in einem dunklen Korridor eine bestimmte Farbe hat
und diese anhand eines Bildes repliziert wenn er selber im hellen
arbeitet hat schon einen Fehler gemacht. Diese vermeintlichen
dunklen Farben sind unter Tageslicht viel heller. Nehme ich
naemlich die dunklen Farben die so wie oben kopiert wurden und
bringe sie dann in Lichtverhaeltnisse wie im Film werdet ihr
merken das diese Farben nun viel zu dunkel sind. Obendrein haben
die Kuesntler die am Set arbeiten z.b. das Gruen der Brustplatten
in vielen verschiedenen Schichten aufgetragen und noch diverse
andersfarbige Farbsprinkler verpasst um Tiefe und Schattierungen
zu erreichen. Da Hasbro nur mit einer Farbe arbeitet bleiben nur
Kompromisse.
Der urspruengliche ESB Helm den Hasbro auf den 3D Bildern zeigte
wurde korrigiert. Leider sah man vorher nicht viel von anderen
Details.
Nun da ich ein paar lose in Hand habe kann ich sagen es ist eine
gute Figur, schoen modelliert und beweglich aber es ist nicht die
perfekte Figur wie einige denken oder erhofft haben. Probleme gibt
es beim Jetpack, bei den Farben, den Stiefeln. Jetpack und Stiefel
ruinieren es fuer mich. Einige wird es nicht stoeren alles Boba
wird eh gekauft, wer aber Wert auf die richtigen Details legt dem
faellt sowas auf. Stoehnen auf hohem Niveau. Warum auch nicht, es
kostet das gleiche es richtig oder falsch zu machen. Dann kann man
es auch richtig machen.
Der Helm scheint nach dem originalen 3D Scan modelliert zu sein
was man an der flachen Stelle oben erkennt und ist identisch mit
meiner Kopie eines echten Helms aus den 90ern. Leider hat der Helm
14 Killstripes wie der ESB Helm, Boba hatte aber zwischen ESB und
Rotj weiter gearbeitet und so war er bei Rotj bei 18 Killstripes
angekommen, dafür ist die orange Farbe der Streifen korrekt, die
Wangen jedoch sind wieder mehr schwarz muessten aber einen
Gruenstich haben. Gebe 9 von 10 Punkten.
Beim Brustpanzer fehlen das Lauflicht links das Gruen ist zu
dunkel. Emblem super, 7,5 von 10.
Das Jetpack ist ein Vorproduktions Jetpack kam zum Einsatz beim
Fett der gelbe und rote Gauntlets trug, die Farben sind viel zu
hell, das blau muss ins gruene.fuer ein Pre-Pro Fett 10 von 10
bei dem Rotj Fett 5 von 10. Geht gar nicht.
Ausserdem hat die Rakete 3 klappbare Winkel nicht 4. Wird immer
wieder uebersehen.
Die braunen Munitionstaschen am Guertel sind gut gelungen inkl.
angedeuteten Naehten. Die Laschen am Ruecken die den Pferdeguertel
schliessen sind vorhanden haben aber eine Struktur, am Original
haben sie keine Struktur sind schwarze Lederstreifen.
Der Overall hat das richtige verwaschene ausgeblichene Blau,
Gauntlets haben die richtige Farbe gute Details bis hin zu den
Knoepfen, am rechten Gauntlet zaehle ich nur 3 von 4 Pfeilen, 9.5
von 10.
Der Umhang hat die richtige Farbe und Laenge 10 von 10. Der
Blaster hat Fehler, die Greeblies am Schaft sind vom ESB Blaster
somit falsch, der Griff hat nur rechts einen Pistolengriff am
Original links ist ein flaches Montiereisen an der Webley, kein
geformter Pistolengriff. der Rost, Form und Groesse sind perfekt
7 von 10.
Der Schulterpanzer kriegt eine 10 von 10 ist an der Weste richtig
angebracht, dadurch laesst sich die Figur auch besser bewegen.
Schulter und Kniepanzer koennten was dunkler orangiger sein.
Die Stiefel, mein groesstes Problem. Das meisste laesst sich oben
durch Farbaenderung korrigieren, die Stiefel,...sehen aus wie
Pantoffeln, deformiert passt nicht und mit dem Gelenk
verschlimmert sich der Anblick. Die Originale haben eine
distinktive Form die ich mir gewuenscht haette. Diese hier schaden
dem Look immens.
Fazit, die Figur hat einen hohen Spielwert und wenn man die obigen
Fehler korrigieren koennte waere es eine 10 von 10 und Hasbro
braeuchte nie mehr an einer anderen Figur zu doktorn. Dieser
Sculpt waere noch in 20 Jahren detailliert genug um zu bestehen.
1   L A T E S T    R E P L I E S    (Newest First)
Commander Cody Posted - 03/13/2021 : 08:03:18 AM
die fehlenden "Chest Lights" sind sogar mir sofort aufgefallen.
Das verstehe ich nicht, dass man das als Designer vergisst - in der Frontalansicht einer Figur??? Das stört mich schon, mit allen anderen von Volker aufgeführten Punkten kann ich persönlich gut leben.
This page was generated in 0.1 seconds. Snitz Forums 2000
